RainbowUnicorn
PC Specification: Intel 3930K, GTX 680, Windows 7 ultimate
Video Quality Worse than shown?
Sun Sep 15, 2013 6:48 pm
I don't know what the Problem is but every time I record a video and I preview it, it looks Crisp and Smooth with the Action! player but the moment I preview it on on Media player, VLC, and Sony Vegas ect ect . It's not 60FPS and has horrible pixelation . My screen resolution is 1920x1200 I'm forced to record in original cause if I try 1080p it doesn't let me drag it into Sony Vegas . I've tried Recording in 60 and 30 no difference. The settings I use are
File Format: AVI
Video Size: Original
Video framerate: 60
Video Quality: High
Input range : 0-255
Using multicore
PC SPECS
Sound Card ASUS Xonar Essence STX Virtual 7.1 Channel
Main Hard drive SAMSUNG 840 Series 500GB
Second drive TOSHIBA 3TB 7200 RPM RP
3rd drive Toshiba 7200RPM 500GB
CPU Intel Core i7-3930K
MotherBoard ASUS Rampage IV Extreme
GPU EVGA SuperClocked+ GeForce GTX 680 2GB
Ram G.SKILL Trident X Series 8GB DDR3 2800 (PC3 22400
Case CFI CFI-A7007 Black SECC
Monitor Dell UltraSharp U2412M
Re: Video Quality Worse than shown?
Tue Sep 17, 2013 12:05 pm
Is it possible that you could upload a sample file somewhere?
Cauptain
Contact: ICQ
Wed Sep 18, 2013 1:49 am
Just install LAV filters. solve problem using other players.
Sony Vegas support 1080p only, no more.
To get 1920x1200 try Virtualdub, its work in any resolution.
Claudio
