neomatic999
PC Specification: Windows 7 64bit, GTX 680
Can't record sound whatsoever
Sun Sep 22, 2013 9:33 am
Hi, I bought this app yesterday with the hope to record some BF3 videos with sound. The video recording works fine but there is no sound whatsoever captured by this software. I have an Asus xonor sound card which is the default playback device. The default recording device is my headset which is also attached to me sound card. The Action software is configured to capture from the 'default'. This should be pretty straight forward and I don't understand why this software isn't doing its job. Can anyone help please?
Re: Can't record sound whatsoever
Mon Sep 23, 2013 2:29 pm
Could you post a screenshot from your Asus Xonar panel?
neomatic999
Tue Sep 24, 2013 9:42 am
Sure thing, thanks for looking into it.
PS: FRAPS works fine with audio & video so it should actually work with your software as well.
I appreciate the help.
Tue Sep 24, 2013 10:12 am
Turn off the special effects on DSP mode (right bottom corner).
neomatic999
Tue Sep 24, 2013 10:55 am
I have done that. No difference. Here are all my settings.
neomatic999
Tue Sep 24, 2013 10:56 am
Windows settings
Fullscreen capture 24092013 85213 PM.jpg (38.21 KiB) Viewed 14138 times
neomatic999
Tue Sep 24, 2013 10:59 am
and more
neomatic999
Thu Sep 26, 2013 9:56 am
Hi, can you help please?
Thu Sep 26, 2013 12:44 pm
Check if changing Sample Rate in your Xonar panel from 96 KHz to 48KHz fix something.
neomatic999
Thu Sep 26, 2013 1:14 pm
OK, that worked now with audio only recording. When I record a video stream I am still not getting the audio with it. Getting closer.
