ROBBOsulsu
PC Specification: Windows 7
Recording Bit-Rate!
Fri Sep 27, 2013 3:32 pm
Quick Question, When Live Streaming on Action! You are able to set the bit rate you're recording at. Are we ever possibly going to be able to set the bit-rate we record with when using default recording?
That'd be really cool :)
Thanks!
ROBBOsulsu
Re: Recording Bit-Rate!
Tue Oct 01, 2013 11:51 am
Currently there's no plans in near future to add customized bitrate for video recordings.
GamerGuy
Tue Oct 01, 2013 6:01 pm
I'd like to 2nd the request. It's one of the things I always thought was missing. I especially would like to be able to set a lower bitrate than the current lowest settings.
