ninorecordings
PC Specification: dont know
Action! on Tennis Elbow 2013
Fri Oct 04, 2013 12:31 pm
Yo,
just downloaded the Trial Version of Action! and wanted to record a video from Tennis Elbow 1013.
Unfortunately this doesn't work. I dont know which direct x version this game uses.
Is it possible to run Action! even if the direct x of the game is not supported?
Thanks for help
Best regards
Nino
Re: Action! on Tennis Elbow 2013
Fri Oct 04, 2013 5:52 pm
This game is running under DX7 or DX8. Action! does not record games or applications which use DX8 or lower. You can try a workaround method and record your game with Active Desktop Region while running your game in windowed mode.
