Aminados
PC Specification: I5 3570k@4.5 GHz 660 Ti 3GB SLI Win8
Please! ENBseries support!!
Fri Oct 11, 2013 12:35 am
I came here to congratulate you on the amazing recording software you've done! But also to make a request if possible, and that is ENBseries suport, right now if I try to record a game that is using ENB it just crashes, PLEASE! support ENBseries!!!
Thank you!!
Sethos
PC Specification: 3930k, 2 x Titans, Windows 8, 16GB Ram.
Re: Please! ENBseries support!!
Sat Oct 12, 2013 3:23 pm
That's not something you just "support" - That would require a whole different way of recording. Most recording software can't record ENB due to the DirectX hook. Only software able to do it is FRAPS because it captures basically at the root of the framebuffer. So I doubt you'll ever see that in Action! or most recording software for that matter.
GamerGuy
Sat Oct 12, 2013 7:26 pm
It would be nice though. Also nice would be if Action could automatically switch between that mode, regular game recording mode, and desktop recording mode on the fly without me having to stop it and choose the modes manually.
sinnfullduck
PC Specification: i7 2600k, radeon 6870, win7
Tue Oct 15, 2013 10:37 pm
I play Skyrim with ENB installed and the game crashes on startup if I have Action open. The way I've found around this is to set Action to record desktop mode. Once I did that it worked fine and the recording was perfect.
pcGAMESmods
PC Specification: i5-4460, GeForce GTX 750 Ti, W10, 32RAM
Fri Apr 21, 2017 11:00 pm
For when a solution is in 2017 and the problem prevails.
