Knockturn
PC Specification: Windows 7
Extracting / using the microphone track
Thu Oct 17, 2013 3:26 pm
Okay, so recording into seperate audio track. I can hear it when I press A when playing it in the Action! player, and after installing the ac3 filter it playes in media player. How do I access that audio track in a video editing software I have premiere pro, and I couldnt access it, I even tried lightworks and a trial of CyberLink PowerDirector.
It cant see or hear it in those. I want to get a seperate audio track for more controle over my videos for youtube. I used audacity to record audio for a while. But sync is off some times.
Re: Extracting / using the microphone track
Fri Oct 18, 2013 7:32 am
Not all video editing software support multiple audio tracks. As far as I know Sony Vegas does. You can always extract your second track to a separate audio file with VirtualDub for example. It's free and it usually take less than minute to export it.
Knockturn
Fri Oct 18, 2013 7:53 am
Okay, thanks.
Primiere Pro supports multiple audio tracks but none of them are the microphone. I might give it a go with virtual dub. Would be nice not having to worry about syncing gameplay with audio but i will prob just stick with recording audio in audacity. Wish it was easier with the seperate microphone.
Will give your program a go. I just dont understand why that perticular audio is "hidden". When I enable multiple audio tracks I get the surround sound is effects with a lot of audio tracks. But no microphone.
