Neo51
PC Specification: FX 8350, GTX 660 Ti, Windows 8.1 Pro
Error recording Desktop
Sat Oct 19, 2013 7:07 pm
Hi, last week i was recording desktop, and i suddenly i got and error, since that happened i can't record desktop, when i select desktop option i don't see the fps and when i click on the red button it keeps saying 00:00 and does not record anything.
http://i.imgur.com/4UZYgHq.png
Re: Error recording Desktop
Mon Oct 21, 2013 4:58 pm
Have you tried re-installing Action! with registry cleaning?
Neo51
Mon Oct 21, 2013 10:15 pm
I'll do it right now
Neo51
Mon Oct 21, 2013 10:25 pm
It didn't work, i still have the same problem.
Neo51
Tue Oct 22, 2013 9:22 am
What should i try to do now?
Tue Oct 22, 2013 2:36 pm
Please contact our support team then via support@mirillis.com.
Neo51
Mon Oct 28, 2013 10:08 am
I contacted them, they told me to do uninstall action! completly, they told me the instructions, i did it and nothing worked, and today i tried to click on record windows aero and entered in a game and this message appeared.
action! error msgbox.png (13 KiB) Viewed 14328 times
Any suggestion?
Thu Oct 31, 2013 1:33 pm
If the errors are still appearing there must be something with your system environment. Probably our support team provided you instructions for complete Action! re-installation. After that your Action! is reset to default. If it's not working, it's probably your system fault.
Neo51
Sun Nov 10, 2013 6:17 pm
Hello, just to let you know that i fixed the problem, i was doing everything your team told me but the simple solution was to change compatibility mode to Windows 8 in the properties of action! :| :| :| :|
something so simple gave me a headache more than a month :? :?
