Vince
PC Specification: 4670k i5 | GTX 660 | Windows 7 64 bit |
Action! with ENB series..
Tue Oct 22, 2013 11:43 pm
Yo,
Recently, i've tried the trial version of Mirllis Action!, and I can't record GTA SAN ANDREAS with my enb, but it's work without the enb.
Please fix it, cause I really like Action! but if it's doesn't support everything..
KyrenCross
PC Specification: AMD FX 8350,GTX 780,WIndows 7,Xonar D2X
Re: Action! with ENB series..
Mon Oct 28, 2013 2:47 pm
I bought Action and Splash Pro Ex as soon as I tried the trial cause I think it's the best recording software and player I have ever tried. I can record full 1080p video on my rig while other capture software failed with low FPS and stuttering.
But if they support ENB and SweetFX, then they will destroy the competition ^_^. I love the effects ENB and SweetFX gives to the game and makes my life easier in editing them in Vegas. With Action I have to edit my video in Vegas to achieve the effects ENB and SweetFX gives to my gameplay videos.
Also if they can add the 60 FPS gameplay while recording at 30FPS like in DXtory, and the 3D recording capability of Fraps, then I would never touch those programs again for anything ^_^.
Hope you guys keep on updating for the best, the other softwares seems dead with no future updates to come.
I hope that won't happen to Action and Splash. Keep up the great work with the softwares and listening to your customers.
You guys are awesome!
Thu Oct 31, 2013 1:32 pm
We are aware of the ENB issue. We will release a fix if it' possible. Graphic injectors interfere with d3d9.dll which Action! use.
sinnfullduck
PC Specification: i7 2600k, radeon 6870, win7
Thu Nov 21, 2013 5:46 pm
I play skyrim with ENB and I've found that if I try to use the game recording mode it wont work but if I use desktop mode it works perfect.
KyrenCross
Sat Nov 30, 2013 8:59 am
Any update on ENB and SweetFX compatibility patch?
There are a lot of game release lately that badly needs those graphical fixes, for the default looks absolutely terrible.
Like "Injustice" >_<.
MrTra1tor
Mon Nov 16, 2015 3:13 pm
radi wrote:We are aware of the ENB issue. We will release a fix if it' possible. Graphic injectors interfere with d3d9.dll which Action! use.
I know that it's a bit late, but have you found a solution?
DJSmith
PC Specification: Intel core i3 10105F, GTX 1650S, Win 11
Sat Oct 23, 2021 4:15 pm
Can you give a solution please?
