TheRA1DER
PC Specification: ASROCK Z77 PRO3+HD6970+i7-3770K+Win 7x64
Intel Quick Sync Issues & Questions
Tue Oct 29, 2013 7:14 pm
Hello, i recently installed the latest AMD graphics driver along with the latest Intel Graphics driver and tried out Mirillis with Intel Quick Sync and i have some issues.
Before we start here are my system specs:
i7-3770K
HD6970
8GB DDR3
Windows 7 x64
AMD Driver nº: 13.11
Intel Driver nº: Win64_15319
First issue, as shown in the attached file is that somewhere along the file, the sound cuts off. This does not happen when recording with regular AVI.
The other problem is that, even though i set mirilis to record at the "original" size (1920*1200) the output file is 1740x1086x12
I also get APP crash when i'm using Photoshop CS6 with intel quick sync on.
That is all,
Cheers.
Also, here are my Mirillis Settings:
maxjones
PC Specification: GTX 765m + i7 4700MQ
Re: Intel Quick Sync Issues & Questions
Wed Oct 30, 2013 3:03 am
i also have this problem...but after trying to install all the codecs, MP4 file (using Intel Sync) when imported to Sony Vegas shows no video...only audio :(
can somebody help ? :?
TheRA1DER
Wed Oct 30, 2013 1:00 pm
TheRA1DER
Wed Oct 30, 2013 1:01 pm
maxjones wrote:i also have this problem...but after trying to install all the codecs, MP4 file (using Intel Sync) when imported to Sony Vegas shows no video...only audio :(
for no video try this: http://sourceforge.net/projects/ffdshow/
maxjones
Wed Oct 30, 2013 2:20 pm
TheRA1DER wrote:for no video, try this: http://sourceforge.net/projects/ffdshow/
i tried this but it didnt work...still only shows audio for MP4. (AVI works fine)
also all i need is just install it yeah ?
Thu Oct 31, 2013 1:30 pm
The weirdest thing is the resolution scale. Original should record your native screen resolution. It shouldn't be scaled.
TheRA1DER
Thu Oct 31, 2013 3:49 pm
radi wrote:The weirdest thing is the resolution scale. Original should record your native screen resolution. It shouldn't be scaled.
Honestly, that doesn't bother me much, but the fact that the sound cuts off completely renders quick sync useless for me since i need the sound for my gameplays and lets plays videos :\
evolution
PC Specification: 3770K, ASUS GTX670 Direct CU II, win7 64
Fri Nov 01, 2013 6:00 pm
TheRA1DER wrote:Hello, i recently installed the latest AMD graphics driver along with the latest Intel Graphics driver and tried out Mirillis with Intel Quick Sync and i have some issues.
i7-3770K
HD6970
8GB DDR3
Windows 7 x64
try Win64_153117, with this driver mine pc's quick sync is working better
but for now I do use exclusive nvidia shadow play for recording which beats mirillis all the way !!!!!!!!!!
it is using gpu H.264 encoder
recording in avi cause fps drops cos my hdd's transfer rate is only 205mb/s, quick sync make micro stutters while playing..
Cauptain
Contact: ICQ
Sat Nov 02, 2013 6:58 am
Hi TheRA1DER,
Can you upload a small video to me? 10seconds only using 1740x1086x12 quick sync file.
For solve audio problem in AVI Action file, read this topic: http://forum.mirillis.com/viewtopic.php ... 350#p41350
Claudio
TheRA1DER
Sat Nov 02, 2013 10:46 pm
Hi TheRA1DER,
Claudio
Hi, the problem is not with AVI files, the audio cutting off only happens with *.*mp4 with Intel Quick Sync.
Cheers
