MrWomble10
PC Specification: Intel i5, Intel HD 4000, Windows 8.1
Action! Exporting Issue
Sun Nov 03, 2013 1:56 am
Hi
I recently purchased Action! and have been using it for a few weeks, it is brilliant. However, After downloading windows 8.1, it stopped exporting my videos. I am not sure if this is something I have done, something the update has done, or just a bug.
Basically, I can record, but when I click "Export selected file" it opens the exporter, then stops at 0%. The expected time still moves up and down, between 15 minutes and 11 hours. But it converts nothing. I left it for 4 hours earlier, and still 0% when I got back.
Please please can someone suggest a fix, or help in any way, as I really want to get recording again. This is by far the best recording software I have used!
Thanks
Re: Action! Exporting Issue
Wed Nov 06, 2013 4:13 pm
Do you use Hardware Acceleration for your video exporting?
MrWomble10
Wed Dec 11, 2013 11:04 am
No, just Action!'s internal exporting button. It turns the AVI into an MP4
