hzer
PC Specification: Win7, Intel i7 3770 4,4 Ghz, GTX670
Full Volume
Sun Nov 10, 2013 9:10 pm
why i can set both up to 100?
I got 2 soundcards and will set the volume after recording!
Re: Full Volume
Tue Nov 12, 2013 1:27 pm
Unfortunately you cannot set both to 100%. It was designed this way to balance microphone audio from your system sounds.
ROBBOsulsu
PC Specification: Windows 7
Re: Full Volume
Tue Nov 12, 2013 3:30 pm
I've gotta say, This has caused quite a problem for me also. Maybe you could add a feature that you can either turn on or off the balancing? That would help out alot of people.
Thanks
