DogFromHome
PC Specification: Pentium 4, Nvidia GT 620, 1gb ram, win7
Audio desync
Sun Nov 17, 2013 8:32 am
I have a problem with audio, at the beginning of the video, it is synchronized, but as the time goes, the video goes slowly out of sync. I'm using the default settings.
You can see the sample here, here and here.
Hope to get a fix :)
Re: Audio desync
Mon Nov 18, 2013 10:32 am
Could you post a DxDiag report?
DogFromHome
Re: Audio desync
Tue Nov 19, 2013 12:53 pm
Here's my DxDiag report:
Rawi
PC Specification: i7-3770k, Radeon HD7970, Win 8 x64
Re: Audio desync
Sat Nov 23, 2013 4:11 pm
I have the same issue.
I think it doesn't occur on every game, but on Battlefield 4 it is almost on every my record which is very annoying :/
I'm attaching my DxDiag
DxDiag.zip
My DxDiag
(11.93 KiB) Downloaded 1220 times
randomsimsy
PC Specification: Windows 7, Intel Core i7, GTX 560Ti
Re: Audio desync
Sun Nov 24, 2013 1:57 am
I had the same problem and posted a thread about it here: http://forum.mirillis.com/viewtopic.php?f=36&t=30845
You guys wouldn't happen to be using USB headsets?
Rawi
Re: Audio desync
Sun Nov 24, 2013 8:26 am
I don't use any usb headset.
I use Xonar DGX + Superlux HD669 (jack) + Zalman MIC-1 normally plugged into back of my sound card.
randomsimsy
Re: Audio desync
Sun Nov 24, 2013 9:19 am
I don't know then. maybe you could try doing a recording with a less elaborate setup, like just a headset plugged in and see what results that yield
Rawi
Re: Audio desync
Sun Nov 24, 2013 9:42 am
I've just tested that recording BF3 is fine.
Desync is only with BF4 so it looks like Action! doesn't support it properly.
I wonder if there is someone who can record let's say 5 minut of BF4 gameplay without any desync.
randomsimsy
Re: Audio desync
Sun Nov 24, 2013 11:32 am
That's why I was wanted to see the results of the test I suggested above. I tried a recording using just a simple stereo headset with no microphone and the recording didn't have any sync issues.
Rawi
Re: Audio desync
Sun Nov 24, 2013 6:14 pm
I'm not sure what do you mean by 'simple stereo headset with no microphone' as Superlux HD669 is just a stereo (jack) headphone without a microphone...
I use separate microphone also plugged into jack.
I've tried different presets (hifi, home cinema, headphones) + surround/stereo in Battlefield 4 and I always have desync.
