lostmellodies
PC Specification: i5 6600K, 16Gb, GTX1060, Win10 1803 64x
Shark007 Codecs confliting with WebCam Recording
Sun Nov 17, 2013 11:23 pm
Hello, i use Action! for a long time and i never experienced a bug before. But now happens that i'm trying do make some tutorial videos using the webcam feature and Action! crashes every time i try to preview or recording with webcam on. I tried to figure out what was going on and i discovered that it happens because a media player codec pack that i use. The Shark 007 Codecs.
I uninstalled it, and the webcam recording works just as it should be.
I Also discovered that it only happens when i uses the Shark007 suggested settings. Just installing the codecs without modifying the settings doesn't seen to affect Action!
It must be some codec conflicting with webcam function, but i can't find what it is! Can someone help so i can use Shark007 codecs (with suggested settings) alongside Action without break the webcam function?
flashmp3
Re: Shark007 Codecs confliting with WebCam Recording
Thu Nov 21, 2013 10:57 am
Why are you using Shark007 Codecs ? Do you really need it ? Or could you remove it ?
Nowadays having only Lav filters installed is enough for most of the people
