Brendan
PC Specification: Windows 8.1 Pro, NVIDIA 630m, i7 3610QM
Action no longer working, help please!
Mon Nov 18, 2013 8:46 am
I recently updated from windows 8 pro to windows 8.1 pro and have found I am unable to use Action successfully.
Previously I had an issue where when I attempted to record a video(all formats) the recording timer would stay at 00:00 and the program would not do anything. I fixed this by enabling compatibility for windows 7 in the properties of action.
I am now having an issue where when I stop recording everything will freeze and all I am able to do is move the cursor around. I have to manually press the off button in order to fix this.
I have tried uninstalling & re installing multiple times, using 2 different versions of action as well as cleaning out my registry files.
Windows 8 pro 64bit
Action 1.16.3.0
Has anyone else had this issue and been able to fix it?
Any help would be appreciated, thanks!
Re: Action no longer working, help please!
Mon Nov 18, 2013 10:15 am
Brendan
Mon Nov 18, 2013 10:46 am
Tried emailing support a few days ago, got a MAILER-DAEMON email a day later saying that my message was unable to be delivered.
Email address was copied & pasted from mirillis contact info, so was definitely correct.
I shall try and send another email I suppose >.>
Mon Nov 18, 2013 10:47 am
Brendan wrote:Tried emailing support a few days ago, got a MAILER-DAEMON email a day later saying that my message was unable to be delivered.
What was the reason your e-mail address was not deliver? Have you tried using another account to contact our support team? A Gmail one should be okay.
Brendan
Mon Nov 18, 2013 11:03 am
Unsure on the reason, its a first :P
I used yahoo to send the email originally, i'll try again now with a gmail as you suggested, thanks.
Users browsing this forum: russellbeckwith and 12 guests
