Jagtitou
PC Specification: Windows Vista SP1
Launching Problem
Mon Nov 18, 2013 6:02 pm
Hi !
Sorry for my english, I'm french... ^^
I have a problem when laucnhign Mirillis Action! The installation is ok but when I try to launch Action! I have this problem :
I run Windows Vista 32 bits and DirectX10.
Can you help me ?
Thank you.
Re: Launching Problem
Tue Nov 19, 2013 8:13 am
d3d11.dll is a system library. Action! only uses it. Probably you are missing it in your system or it has been somehow relocated.
Jagtitou
Tue Nov 19, 2013 6:14 pm
I can't find it in my computer... Maybe I do it the wrong way but...
If it is missing, is it possible to download it somewhere ?
Thank you for your answer.
Wed Nov 20, 2013 7:18 pm
Jagtitou wrote:I can't find it in my computer... Maybe I do it the wrong way but...
Well, re-downloading usually does not work, but you can try. I would suggest system re-installation.
