ROBBOsulsu
PC Specification: Windows 7
Java Crashing Urgent!
Sun Nov 24, 2013 3:28 pm
Hey Guys, So the main reason I've bought this software is for the ability to record games such as Minecraft.
However, I cannot play minecraft whatsoever with this recording software. Even whilst it is windowed Action! causes it to crash. I've tried putting Action! into hiding the HUD but this has absolutely no effect.
Please, Please, Please take a look into the bug. I'm sure this is an inconvenience to alot of players on here.
Thank you!
Re: Java Crashing Urgent!
Wed Nov 27, 2013 6:45 pm
What's your Windows bit version?
ROBBOsulsu
Wed Nov 27, 2013 8:28 pm
64 bit. I've currently got the latest version of Java 64 bit installed. I've tried 32 bit, and I've tried both but neither have success.
Fri Nov 29, 2013 10:41 am
Usually it helps to install the 64bit java version. Have you tried recording Minecraft using Active Desktop Region?
ROBBOsulsu
Fri Nov 29, 2013 1:50 pm
I have yes, It works but that isn't really the point. Luckily for me It's not that much of a bother atm, but It's something that really needs fixing (as I'm sure the majority of users use Action! for minecraft) and it's really bothersome.
