adam777
Splash Lite, Windows 7 x64 and DVB-T
Mon Dec 14, 2009 5:22 pm
I've contacted your support about a month ago rearding issues with Splash Lite 1.0.5 DVB functionality and Windows 7 x64.
Basically, when trying to perform channel search, nothing happens no matter how long I wait (see attached image).
I was informed it was a known issue and that it's on the TODO list.
I just want to ask if there's some progress regarding this issue, as I see nothing mentioned on the 1.0.6 thread.
Thanks in advance and keep up the good work, Adam.
Re: Splash Lite and Windows 7 x64
Mon Dec 14, 2009 11:17 pm
Hi Adam,
The problem is still being investigated. At the moment we know that this problem concerns specific tuner models. We expect that it will take some time for a fix as we do not have your tuner model in our labs yet, but it is on our order list and as soon as we have it we will fix this problem ASAP. We will keep you informed.
adam777
Wed Dec 16, 2009 10:47 am
OK.
Thanks again :)
Dorer
PC Specification: E6300 GF7600 Windows 7 x64
Thu Dec 31, 2009 4:24 pm
Unfortunately, this problem still exists on ver. 1.1 :/
--update--
I'm user of Terratec Cinergy 2400i DT TV Card.
Kaching
PC Specification: C2D 2GHz, 4GB, 320GB,Win7x64U
Sat Jan 02, 2010 3:02 pm
Hi, i`a using Gigabyte U8000 hybrid that uses DibCom tuner and i have the same problem. Running Windows 7 Ultimate x64, but tried in Vmware Windows XP Pro and everything worked.
Today tried the new version of Splash and it shows me error when i`m opening program.
"Critical error during initialization
This application cannot be executed."
Changing compability modes doesn`t help. :(
adam777
Mon Jan 04, 2010 11:35 pm
Tried 1.1 myself.
The result - Splash Lite crash as soon as I try to enter the TV tab.
adam777
Re: Splash Lite, Windows 7 x64 and DVB-T
Fri Jan 15, 2010 9:08 am
Moving on to 1.2
Splash Lite isn't crashing anymore like in 1.1.
But back to the beginning - nothing happens on channel scan.
Watchman
Sat Jan 16, 2010 2:49 pm
adam777 wrote:Moving on to 1.2
Hello adam777,
What region have you selected in the TV settings (Europe, Australia... etc.).
Thanks for the info.
adam777
Sun Jan 17, 2010 8:20 am
Hello Watchman,
Tried about anything, even manually selecting the needed frequency, but europe seems right.
I believe it's some kind of initialization problem,as the activity light never goes on in the receiver.
Oh, I see I forgot to write my model, it's recognized as AF9015 BDA.
ariely
Tue Jan 19, 2010 11:36 am
Having the same problem.
I'm using ec168 based usb device on windows 7 x64.
