Dobs
Intel Quick Sync question
Fri Dec 13, 2013 2:21 pm
So I am looking at this tutorial http://mirillis.com/en/products/tutoria ... s.html#top, and I'm wondering if I can do this if I already use 2 Monitors and I'm running SLI on my video cards?
Will I see a difference in my systems performance that is noticable?
Thank you,
Dobs
Dobs
Re: Intel Quick Sync question
Wed Dec 18, 2013 6:16 pm
Looking for an answer on INTEL quick synch....
System Specs:
Two vid cards running in SLI: EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP
G.SKILL Trident X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2666 (PC3 21300) Desktop Memory Model
GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3770 Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I73770
Any reason why it doesn't see INTEL Quick synch as an option in windows 8.1 Pro?
Dobs
Fri Dec 20, 2013 5:06 pm
<chirp chirp>
Mon Dec 23, 2013 2:44 pm
Sorry Dobs that no one replied here. As far as I know there was some issues with SLI cards and Action!. If it working it should affect much of your performance.
Dobs
Thu Jan 02, 2014 7:38 pm
So, Intel Quick Sync has issues with SLI? Is that the translation of your post?
Thu Jan 09, 2014 1:29 pm
Dobs wrote:So, Intel Quick Sync has issues with SLI? Is that the translation of your post?
I don't know if it's related only to IQS but SLI cards cause Action! to act weird.
Dobs
Tue Jan 28, 2014 8:44 pm
Any change in SLI setup and Action! with the use of Intel Quick Synch?
I can record fine in SLI, but have to use AVI. Would love to be able to use Quick Synch and do MP4, and then export direct to youtube.
Just wondering if this was addressed in latest build.
Dobs
