nunatak
Features suggestions
Fri Jun 18, 2010 5:55 pm
I have some suggestions for new features:
* DVB-S, FM and Analog tv-tuner support.
* Better subtitles font-size customization.
* Option to change the height and font of subtitles.
* PGS subtitles support.
* FLV/F4V support.
* Showing language and channels info on "Audio tracks" list.
* WMV support.
* DVD support.
* Black bars crop for 4/3 videos that are actually 16/9 video.
* Hebrew GUI.
* Wider subtitles sync adjustment option.
* Make the information window "hover" so it will be possible to move it in/out the player window and to change it's size.
* Record option for tv-tuner.
icsterm
Contact: Yahoo Messenger
Re: Features suggestions
Sat Jun 19, 2010 4:51 am
+ 1
WMV support should be on top.
DGMurdockIII
PC Specification: AMD Phenom, ATI Radeon HD 4600 Win764bit
Sat Jun 19, 2010 6:36 pm
some good suggestions there
NumB
Sun Jun 20, 2010 6:59 am
i support these suggestions too... and furthermore, some fixes to the current version will be also welcome.
fullhd_fan
PC Specification: Intel E6400, NVidia GForce 7650GS, Vista
Tue Jun 22, 2010 10:47 pm
My dvb card software (DVBDream ver. 1.4i) has an option to send the mpeg2 and h264 received streams to players using some kind of command line (see the attachement below). Can you add such feature to splash ? Such feature would be perfect providing that splash is the fastest player for h264 streams on my PC, and the DVBDream software cannot play them (it plays only mpeg2 with external codecs).
Terry
Re:
Thu Jun 24, 2010 9:50 am
fullhd_fan wrote:My dvb card software (DVBDream ver. 1.4i) has an option to send the mpeg2 and h264 received streams to players using some kind of command line (see the attachement below). Can you add such feature to splash ? Such feature would be perfect providing that splash is the fastest player for h264 streams on my PC, and the DVBDream software cannot play them (it plays only mpeg2 with external codecs).
looks nice!
MilesAhead
PC Specification: AMD Phenom 9850 Nvidia GeForce 9600 GS
Fri Jul 09, 2010 3:06 am
DGMurdockIII wrote:some good suggestions there
I would add a setting to change the background color. It's annoying to have to "feel around" with the mouse until I happen to hit on a control. Life would be simpler if I could see them and just click on them instead of hunting.
nunatak
Fri Jul 09, 2010 12:17 pm
What are you talking about? The controls and the background color is different, maybe you have some bug.
MilesAhead
Fri Jul 09, 2010 10:48 pm
nunatak wrote:What are you talking about? The controls and the background color is different, maybe you have some bug.
It's not different enough for me. If you have flat screen maybe there's higher contrast, but I'm still using CRT. To me dark purple on black is not contrast. Anyway, what's the big deal of having an adjustable background color? It's one property on a form when you program it.
btw I doubt it's a bug since it looks the same on Windows 7 32 bit and Vista64 on 2 different PCs.
It's more likely that CRT doesn't distinguish dark colors on dark background like flat screen does.
Same with all these lame web sites with dark text and a dark background. It's a pita and there's
no good reason for it whatsoever.
vvcpheus7
PC Specification: Phenom x4 2.6 Ghz, 9800GTX+, Win7 x64
Wed Jul 14, 2010 9:29 pm
Hi!
I have some more suggestions for new features:
* read metadata of mp4 video files
* media library
* import and export media library
* normal lists and smart lists
* preview in thumbnail in the same list/smart-list (like itunes)
* possibilite for use divx h.264 codec (this one is best quality when you advance fast in 1 seg, 1seg the video..)
* native support for 64 bits sistems.
with this will be perfect player and mirillis will be my hero!!! ;)
