Fergo
PC Specification: Q6600, GTX660Ti, 4GB RAM, Win 7 HP
Settings messed up - nothing changes
Sun Dec 22, 2013 5:16 am
Hi!
I'm having some issues with both desktop and game recording.
Doesn't matter what framerate I choose, Action will always record at 30fps. The same goes with the resolution, it will always record at the original resolution when in AVI and in 1152x720 when in MP4 (no idea why). For some reason, the desktop recording also records always to 1152x720.
Any idea on why this might be happening?
EDIT: Nevermind, I've found the issue. I had LIVE Streaming enabled (although even with the "Record Streamed Video to Disk" unchecked, it was saving it with the issues I mentioned above). Anyway, here's a suggestion: make that you have live streaming enabled a bit more clear to the user (and how it can affect the recorded media).
Thanks in advance
