Wololo
PC Specification: Win 7 x64
Refined but Stiff
Wed Jan 08, 2014 9:22 am
I am enjoying the trial of the software but I have some issues with it that are making me consider alternatives.
One of the big draws for me is the ability to include the webcam without having to load up sony vegas. However, it is limited. For one, the overlay image can only be placed under the webcam video and not over, I really feel like there should be a toggle box for this. Second, There should be a way to set the margins for the webcam video so that I can set it to 0 and have the video flush against the walls of the corner rather than leaving a small gap. Three, multiple image overlays really should be a thing, I really don't see why there is only one and the only way to work with this without using vegas or other software is to make a very large image and work from that with a lot of empty space.
As a side note, something odd I noticed. In APB: Reloaded I get a 10fps drop when switching the framerate from 60 to 30.
Re: Refined but Stiff
Thu Jan 09, 2014 12:51 pm
As a workaround for multiple overlays I can suggest a PNG image with your native screen resolution where you locate all the images you want to add into your video.
