Maty
PC Specification: i7 3770 3.4 GHz, Nvidia, 16 gb ram
Can't record HD
Fri Jan 10, 2014 6:43 pm
hi, i just got the trial to test and i cannot record HD even tho i have good settings.
It records avi but the quality is bad, if i export it, it will be mp4 and still looks bad
why doesn't work to record hd? please help
win 8.1, intel i7, nvidia
WelshDevil
PC Specification: Win10 64, Radeon R9 280, FX6300 4.4GHz
Re: Can't record HD
Sun Jan 12, 2014 6:30 pm
Well you are reducing the bit-rate and resolution during export so naturally quality will go down from 1080p.
Another possibility is because of your use of Nvidia CUDA, which is known to reduce quality a little, so try it out with this switched off.
Also, could you post a screenshot of your recorded video in full screen so we can see what is looks like.
Could you also tell us what your monitor or screen resolution is, as well as the model of Intel i7 CPU and Nvidia GPU you have in your PC.
Maty
Re: Can't record HD
Sun Jan 12, 2014 7:07 pm
Here is the video i just recorded
http://www.youtube.com/watch?v=MPft9R3R ... ata_player
this is how i uploaded it http://i.imgur.com/ml8co03.png
this is screenshoot from action video preview
http://i.imgur.com/REl0cr7.jpg
I have i7 3rd gen 3770 3.4 GHz, and video have Gigabyte GeForce GTX 560 OC 1GB DDR5 256-bit
with other player i have no problem recording hd.
how do i disable that Nvidia CUDA?
Monitor is 1920 x 1200, dell u2410
WelshDevil
Re: Can't record HD
Sun Jan 12, 2014 8:12 pm
Well because your monitor is not 1920x1080 set the recording resolution is "Original", and CUDA can be turned off by going to Settings, Export Settings, and remove the tick on "Use hardware acceleration for video encoding".
The only other thing that might be affecting quality is what has been set in Settings, Video Recording Settings and "Video Quality". If not set this tab to "High". Then again I think that might just be the quality that action gives out at 720p, if you want it to be better before export set "Output" to Original and set the bit-rate to the maximum.
Nothing other than that can be done, Action! still has fantastic quality when compared to others like Bandicam or FRAPS (with the first being around the same and the second worse because of the CPU usage).
WelshDevil
Re: Can't record HD
Sun Jan 12, 2014 8:50 pm
Ive uploaded a quick test of what my video looks like with the 720p (Main Profile) Preset, which you can find here:
https://drive.google.com/file/d/0B5vrvi ... sp=sharing
There is a difference in quality and I'm not sure why. It's either because of Nvidia CUDA, or because "Video Quality" is set to something else other than High. If none of these solve the problem, try a reinstall. Other than that I don't know.
I also just wanted to mention at this point that if you are planning on using a different recording software you should still stick with Action, there are some interesting features on the way and it could be fixed in an update. Still it's your choice though so none will mind.
Maty
Re: Can't record HD
Sun Jan 12, 2014 9:04 pm
done what you said above, still same qualitty
whatever i do, on export it gives mp4 instead of avi
Cauptain
Contact: ICQ
Re: Can't record HD
Mon Jan 13, 2014 4:15 pm
Just record using AVI mode without NVIDIA CUDA (Horrible image quality in my tests).
After this, encode to MP4 using RIPBOT264.
For fit in 1080p, just set letterbox 1728x1080
http://i.imgur.com/NldawYL.jpg
Claudio
Maty
Re: Can't record HD
Tue Jan 14, 2014 5:27 pm
Thanks Cauptain, but still same result
settings http://imgur.com/a/2ss4V
the main avi is looking bad, so you can't export HD if the "source" avi isn't quality
Am i the only one having this problem? this sucks :(
