stmalk
PC Specification: i7-3770, 3.4 Ghz, GeForce 660 Ti 2 GB
Mirillis doesn't work with SweetFX
Wed Jan 15, 2014 4:49 pm
I was trying to record HL2 with SweetFX enhancement on, but Mirillis simply doesn't detect the game. I was trying the same with EuroTruck Simulator 2. When I used SweetFX, Mirillis simply didn't see the game, there was no overlay and I couldn't record anything. Once I removed ENB files from game folder, Mirillis started working. I believe SweetFXworks as some kind of overlay added to the game or something, I don't know. But this is a huge disappointment for me. I love playing games with ENB and SweetFX injectors to have improved graphics, but Mirillis falied to record it in all versions. And it was never fixed. :cry:
suppy
PC Specification: windows 7
Re: Mirillis doesn't work with SweetFX
Sun Jan 19, 2014 9:15 am
Is there any way to record with SweetFX enhancements on?
Tue Jan 21, 2014 1:33 pm
We are investigating the SweetFX issue. As for now there is no possibility to record games with SweetFX enabled in Game/Application mode.
DJRiful
PC Specification: 3930K, GTX TITAN, Windows 8 Pro 64bit
Fri Jan 24, 2014 2:02 am
Set the game at Fullscreen Windowed mode and record it as Desktop mode.
Done it with mine: https://www.youtube.com/watch?v=WwHeVriyFNc
SnQQpy
PC Specification: i7 3930K:GTX470 4GB Sli:32GB:Win7 ProX64
Tue Mar 18, 2014 2:11 am
Have we any date on fixes? - while I'm relatively new to the boards the one thing I'm noticing, is that the Mirillis team members appear quite evasive and mostly don't answer any questions put direct, other than in a vague way. For instance acknowledging an issue isn't the same as saying yes we are going to fix it! I think what people need to see, is that here is a 'RoadMap' eg 1,2,3 etc is planned for version X. I hope this apparent ambiguity isn't deliberate because that would be bad.
Anyway for anyone using SweetFX, and windowed mode isn't feasible or desirable for you, then try Bandicam in the meantime. I use it for SweetFX rendered games at the moment and in fact did just that today for LA Noire. :)
Asus RIVE
i7 3930K (C2) Unlocked
Corsair H80i Hydro
Dominator 32GB 1866 DDR3 Quad
4GB GTX 670 SC X2 SLi
Samsung 256GB x2 830 SSD RAID 1
HDD: x2 WD SATA III 1TB WD Caviar Red
Dell Ultrasharp U3011 30" LCD IPS + 2x24" Samsung 2443
Win7 Pro x64
catalinasgrace
PC Specification: AMD 8350, Nivida 670gtx 4gb, win 8.1 64
Fri Jan 02, 2015 12:28 am
Has there ever been anything said or done about this? It has been a good while, and Action still does not work with sweetfx while all the rest do...
I hope this does in fact get fixed...
pcGAMESmods
PC Specification: i5-4460, GeForce GTX 750 Ti, W10, 32RAM
Thu Feb 16, 2017 1:43 am
My Grand Theft Auto + ReShade + ENB crashes at startup if Action Mirillis is on
But if I use my Grand Theft Auto without the ReShade + ENB and the Action Mirillis turned on the game normally.
I need a resolution to this problem because I bought a license from Action Mirillis to be able to record my games.
And I want to record and play with the features I want Grand Theft Auto + ReShade + ENB
