Abacus
Aero and Splash Lite
Mon Dec 14, 2009 7:22 pm
Hi, Splash Lite disables Aero, when i open it. I dont want to disable Aero but Splash wants.. OS: Windows 7 X86
Watchman
Re: Aero and Splash Lite
Mon Dec 14, 2009 9:56 pm
Hello Abacus. Please make sure that you have "Force video overlay" disabled in the video settings panel (Video output section). This should usually be disabled by default on Windows 7 except for Intel GMA945/950 (in this case Splash is forcing to disable Aero to improve display performance).
Abacus
Tue Dec 15, 2009 12:12 am
Thanks but unfortunately it was already unchecked. I checked and unchecked again but nothing changed..
Watchman
Tue Dec 15, 2009 9:18 am
Could you please specify your graphics card vendor and model? It's probably Intel but an exact destription would help us in solving this problem.
Thanks!
Abacus
Tue Dec 15, 2009 5:26 pm
Mobile intel 945 express chipset family, Intel gma 950 chipset. I'm using a netbook.
Fri Dec 18, 2009 11:47 am
On your Intel GMA945/950 Splash forces to disable Aero to improve display performance.
We are sorry but this can not be changed by the user.
guettomusick
PC Specification: Netbook Asus; Desk Core2D Nv9; W7 Both
Thu Jan 14, 2010 11:31 pm
Mine not only disable aero, which I don't bother at all, but it doesn't show any video. I have 2 PC, a desktop PC, which works fine, Nvidia Graphic Card, and a Asus Netbook, Intel GMA950 Graphic Card with this issue.
Mon Jan 25, 2010 11:07 pm
guettomusick wrote:Mine not only disable aero, which I don't bother at all, but it doesn't show any video. I have 2 PC, a desktop PC, which works fine, Nvidia Graphic Card, and a Asus Netbook, Intel GMA950 Graphic Card with this issue.
Do you have the latest graphics drivers installed? Usually drivers update solves this problem.
What type of video do you playback (open Splash info panel - press "i" - to check stream and video type)?
