Montago
Action 1.17.1 bugs / errors / problems
Thu Jan 23, 2014 10:25 pm
I've just upgraded from 1.16.3 (which works perfectly)
I've recorded two videos in Game mode, 720p60, QuickSync enabled using Virtu MVP 2.0
150MB MP4
https://mega.co.nz/#!2FIgABJD!cG9dRjMdg ... 6Wg3hmNGNc
68MB MP4 (the worst)
https://mega.co.nz/#!qVgUnZSS!WY5kmw7Aa ... eKXD01lygc
I'm getting a ton of framedrops, and skips, and crazy :(
the big video was not so bad, but the small one is really bad :(
Re: Action 1.17.1 bugs / errors / problems
Fri Jan 24, 2014 9:30 am
Could you send your feedback to our support team?
Montago
Fri Jan 24, 2014 9:32 am
Sure...
GamerGuy
Fri Jan 24, 2014 4:16 pm
After installing 1.17.1 today, the first desktop recording it made after that failed. When I stopped the recording, Action just got stuck and hung without properly closing the file. Rebooted the computer and now it seems to be working ok.
Claunator
Mon Jan 27, 2014 7:29 pm
I feel the games/applications mode is practically pointless in this version. The screen recording mode lets the HUD show up in my games automatically which i find very convenient, no need to alt-tab after launching a game anymore :) i guess that's what it meant with continuous recording.
However i have some problems too: Just Cause 2 crashes every time i hit record as well as Mafia 2 (after launching a chapter). With 1.16.3 i was able to record Just Cause 2.
When i launched it after hitting record on desktop to see how it would go, my screen flickered and turned green for a second, then i got a box saying "Just Cause 2 stopped working ".
Oh and Steam Overlay works pretty well now with Screen mode, it even lets me record it.
superdoodleguy
PC Specification: AMD Athlon II X4 ,AMD Radeon 7700, Win7
Computer Crashing Bug
Thu Jan 30, 2014 2:15 pm
I have been using action for a while and never have experienced any problems, however since updating to 1.17.1 on opening of the application my PC has displayed vertical lines and then shut down. I have re-installed the software numerous times however this has not solved the problem. I also restored my computer to factory settings but this has made no difference so for now I am sticking with a slightly older version which still works fine. If anyone knows a fix for this please could they reply.
Wed Feb 05, 2014 12:53 pm
Please try updating your Action! to 1.17.3.
