DJRiful
PC Specification: 3930K, GTX TITAN, Windows 8 Pro 64bit
Suggestion: Disable HotKeys
Fri Jan 24, 2014 1:31 am
Can we have an option to disable some of the hotkeys that I won't be using? Right now it looks like it forces me to fill up every single box function for a hotkey and what if my keyboard (simple) is limited and I don't want to have those additional keys to interfere my game or applications. Especially playing MMO with multi-keys already. It is a headache to find some combo keys that no application will use to fill those boxes on those unneeded features like Detect Framerate...
The uncheck function is not enough and it is confusing. Should be clear out that box no need to fill in any keys when it is disabled.
DJRiful
Re: Suggestion: Disable HotKeys
Fri Jan 24, 2014 2:39 am
Need to support Middle Mouse button as well.
Fri Jan 24, 2014 9:28 am
You can disable a hotkey using tickbox next to the hotkey.
WebMaximus
PC Specification: Intel Core i7 2700K, GTX 680, Win7 x64
Sat Jan 25, 2014 12:11 pm
radi wrote:You can disable a hotkey using tickbox next to the hotkey.
However this still isn't true for the first 4 hotkeys which are always enabled whether you like it or not.
I asked about this long time ago and I can't honestly see why the same thing still is true, should be a fairly easy thing for you to fix allowing also these hotkeys to be disabled if the user don't use them?
Mon Jan 27, 2014 4:47 pm
They cannot be removed/unticked for technical reasons.
