Action! 1.17.1 & 1.17.2 & 1.17.3
Mon Jan 27, 2014 11:07 am
New in 1.17.1:
- NEW FEATURE: Replaced Active desktop recording mode with Active screen recording mode (continuous desktop/fullscreen applications recording)
- NEW FEATURE: Support for AMD APP acceleration added. Available both for real-time MP4 recordings and for exporting AVI to MP4.
- IMPORTANT: Improved recording performance (up to 20% less CPU/GPU usage)
- Fixed Call of Duty Ghosts recording
- Fixed regular video stutter (in 1 second intervals) in some situations
- Removed microphone noise when using very sensitive microphones (low volume microphone setups)
- Improved support for 3rd party video editing software
- Stability improvements
- GUI improvements
New in 1.17.2:
- Fixed Windows 8.1 Modern UI apps recording
- Fixed HUD recording timer
- Improved DirectX 10/11 games detection
- Stability fixes
New in 1.17.3:
- Fixed support for systems with AMD GPUs and non-vendor certified drivers
- Stability fixes
GamerGuy
Re: Action! 1.17.1
Mon Jan 27, 2014 8:10 pm
Can you explain more the difference between the new Active screen recording mode and the old desktop recording mode? What are the advantages/differences? Thanks
Montago
Re: Action! 1.17.1
Mon Jan 27, 2014 10:06 pm
how does AMD APP work ?
does it use the ATI GPU to encode video while im playing ?
I just recorded 10 minutes at 1080p60 with outstanding good result !!!!
- no frames lost
- no lag
- no frameratedrop
- no performancehit
720p60 @ 130 MB/minute
1080p60 @ 200 MB/minute
just perfect !!
Ghost2081
PC Specification: i5 2500k Stock, AMD 7970 Ghz Edition, W7
Re: Action! 1.17.1
Wed Jan 29, 2014 10:14 am
Trying to record A Metal Gear Rising Revengeance Gameplay, but when I export the file on Vegas, I can hear audio only in the cutscenes. Not sounds during gameplay... Why?
Dobs
Re: Action! 1.17.1
Sat Feb 01, 2014 3:53 pm
Very buggy release in my opinion. I have had more crashes since installing this version than I have had in the entire two months of using the previous version.
Hitting Video Capture in game locks my system up periodically/randomly, and also sometimes does not record. Don't see the HUD go to red/30fps, and when I look at the action screen, it is a white background, incomplete video....basically doesn't fully start.
Before the comment is made "what is your machine specs", I'll toss out I have 400+ video's on youtube with ACTION! as the recorder....from the previous version 1.16.3.0. So, its not on my end, its on the new release.
I love the product, love what it can do (although can't get Quick Synch to work..and think its because I'm running SLI mode), but something is glitchy in the new release.
I just rolled back to the previous version, and will wait to test the new version again once I see/hear about patches being made.
Dobs
Re: Action! 1.17.1 & 1.17.2
Tue Feb 04, 2014 8:04 am
New 1.17.2 update is now available with:
- Stability fixes
Re: Action! 1.17.1 & 1.17.2 & 1.17.3
Tue Feb 04, 2014 10:35 pm
New 1.17.3 update is now available with stability fixes and fix for Action! startup on some systems with AMD GPUs and non-vendor certified drivers.
n3v3rm1nd
PC Specification: MSI GT60
Fri Feb 07, 2014 5:37 pm
I hope its better ! I got a corrupted Recording wirh 1.17.2 because my game crashed ! Never happended with 1.16 ..
Whats missing :
List for Forcing Action on Specific Games, talking about Starbound OpenGL, doesnt work
More Webcam Controls its always to dark
When starting Recording and the Sound level in Mirillis for the Microphone is different than in Windows it will set it at that volume that is in action (Bug) even when not recording the microphone ! apart from that
Best recording experience ever ... waiting for Nvenc recording ;)
Gamer17
PC Specification: Windows 7
Sun Apr 06, 2014 7:52 pm
Hello After recording a video it reproduces in 1.5 - 2 times faster than the normal speed. What's the problem?
Kilda
PC Specification: Win7, i5-3570@3.4GHz, AMD 7800 series
Tue Jan 27, 2015 2:15 pm
Hi, after new version is installed in Steam, my in-game video record has audio issue. My audio recording becomes choppy / crackling. It has not happened to me before until very recently. My recording was working perfectly. Sample as follows. It has become really bad. Thanks for looking into it.
http://youtu.be/ODSBWi9ZKG0
OS: Windows 7
Video Card: ATI Radeon HD 7800 Series.
Memory: 8 GB
Resolution: 1920x1080
Video Editor: None
Game Problem: Marvel Heroes 2015, Skullgirls, Prison Architect ... I have tried multiple games and still having same issue.
Video Type: MP4 (AMD)
