Qwynn
PC Specification: No
Action! 1.17.1.0 Crashes/Freezes on Export
Thu Jan 30, 2014 12:01 pm
The title more or less says it all.
When attempting to export gameplay footage from Action!, it will crash more often than not. While I have been able to completely export some videos correctly (and the quality is outstanding), it takes me about two hours of constantly retrying until I finally get lucky enough for it finish without a crash.
The crashing appears at random percentages, and I have seen it as low as 4% and as high as 98%.
The footage in question is recorded at 1920x1080 @ 30 FPS, with an approximate length of around 30 minutes. File size ranges from 8 to 13 GB.
I am attempting to export this footage at 1080p (High Profile),
Sometimes the footage will export without problem, however, as I type this I am currently on restart number #17 of a particular file. I know the raw footage is fine from viewing it in both the Action! player as well as WMP.
Is this a problem others are having? Is it just my luck? I've attempted uninstalling and reinstalling Action!, as well as changing the export folder to various different ones ranging across all my HDDs and SSDs.
Recording footage works perfectly as always; it just seems to be the export function that is giving me trouble.
Re: Action! 1.17.1.0 Crashes/Freezes on Export
Wed Feb 05, 2014 12:53 pm
Could you post your DxDiag report?
