Dobs
Action 1.17 New release not ready for prime time
Sat Feb 01, 2014 4:03 pm
Very buggy release in my opinion. I have had more crashes since installing this version than I have had in the entire two months of using the previous version.
Hitting Video Capture in game locks my system up periodically/randomly, and also sometimes does not record. Don't see the HUD go to red/30fps, and when I look at the action screen, it is a white background, incomplete video....basically doesn't fully start.
Before the comment is made "what is your machine specs", I'll toss out I have 400+ video's on youtube with ACTION! as the recorder....from the previous version 1.16.3.0. So, its not on my end, its on the new release. But here is my system specs anyway:
GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
2 x EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready vid cars in SLI mode
Intel Core i7-3770 Quad-Core Processor 3.4 GHz 4 Core LGA 1155
G.SKILL Trident X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2666 (PC3 21300)
Record on to a SSD which is not my OS drive (but that is SSD as well).
I love the product, love what it can do (although can't get Quick Synch to work..and think its because I'm running SLI mode), but something is glitchy in the new release.
I just rolled back to the previous version, and will wait to test the new version again once I see/hear about patches being made.
Dobs
Claunator
Re: Action 1.17 New release not ready for prime time
Sat Feb 01, 2014 4:47 pm
Very weird. Maybe u have certain applications in the background that might cause it. What settings are u using? Are ur drivers updated?
Sethos
PC Specification: 3930k, 2 x Titans, Windows 8, 16GB Ram.
Sat Feb 01, 2014 10:17 pm
I must agree, I've had nothing but problems with it
Dobs
Tue Feb 04, 2014 4:14 am
Rolled back to previous version...and had ZERO problems since I rolled back. Beta was so buggy I used it twice..Release was so buggy it forced me to roll back a version.
DH48
PC Specification: Alienware M18, I7-4700qm, Sli 780, win 7
Tue Feb 04, 2014 6:02 am
So far no problems with the new update.
majik
PC Specification: 2600K, HD5870, Windows 7 Professional
Tue Feb 04, 2014 1:33 pm
Dobs wrote:Rolled back to previous version...and had ZERO problems since I rolled back. Beta was so buggy I used it twice..Release was so buggy it forced me to roll back a version.
How did you roll back? The new 1.17.2 is making my BF4 crash every now and then saying something about virtual memory being too low. I didn't have this issue in 1.17.1.
Wed Feb 05, 2014 12:45 pm
Please update to 1.17.3. Some fixes for AMD cards and Action! crashing were added.
Users browsing this forum: No registered users and 43 guests
