skpManiac
PC Specification: Intel i9, 3080Ti, Win 10 Pro x64 64Gb
Adding watermark crashes App
Mon Feb 17, 2014 3:38 pm
Hi there, when you released the last Beta I posted that if you click to add watermark, the app crashes.
Well this new release has the exact same bug - the only way to fix it is to go back to the old version :/
The app bombs as soon as you click the OPEN folder to browse for a file :/
Please fix this.
Re: Adding watermark crashes App
Fri Feb 21, 2014 3:00 pm
Have you tried updating to 1.17.4? We have added our own file browsing mechanism.
skpManiac
Fri Feb 21, 2014 3:18 pm
ok, that version was not there obviously, as it had only just updated.
That works
However I think I must say that the browser is horrible :/
I have 6 drives in my PC, and the browser does not show drive NAMES only letters and the actual look is horrendous, why not make it use Explorer or at least LOOK the same as explorer?
I think this is total overkill and unnecessary programming when Windows SDK's has all this built in for devs as standard - LESS IS MORE is very accurate in this case.
skpManiac
Tue Feb 25, 2014 9:07 pm
did you know the new version does not record in Game Mode?
I am getting really frustrated that every update BREAKS something!
Maybe you need Beta testers so the app actually works when you release it?
