Kyler45
PC Specification: GTX 760ti 4GB VRAM,12GB RAM,Intel I5 750
Question regarding Action! Licences
Fri Feb 21, 2014 1:40 am
Hello!
I just recently purchased the commercial version of Action! for my youtube channel, and I purchased 1 License. From what I have read, this license is used for one computer only, correct?
I have heard that having multiple licenses allows you to work with both computers simultaneously. Does that mean I can activate Action! on my laptop, with this license, and use it as long as I don't have action in use on my desktop? I wouldn't be using both at the same time.
Re: Question regarding Action! Licences
Fri Feb 21, 2014 2:54 pm
One single license allows you to activate Action! on one computer at the same time. If you would like to use the same license on two different computers you'd have to uninstall it before installing it on new one.
