BettaFish
PC Specification: Windows 7
Uninstalled Action!
Fri Feb 21, 2014 9:08 pm
I had some errors with Action! , so I decided to uninstall it and then reinstall. I uninstalled it , and downloaded the Action! trial (as there was no other download button) but when i opened it , it said ''Your trial has expired''.
How do i get my purchased Action! back?
grimlp
PC Specification: Core i7 @ 920, AMD R9 280x, Windows 8.1
Re: Uninstalled Action!
Sat Feb 22, 2014 2:31 am
You should have an email from when you purchased it with a key.
Zanezeroqwe
PC Specification: Intel core i7, Geforce GTX 650, Win. 7
Sat Feb 22, 2014 4:06 am
Simply click on the button that says "i" in the upper right hand corner. Then you should see something about registering, enter the key you received via email there and you should be able to register it again.
supercars22
PC Specification: Intel Pentium B970,Windows 7
Sun Feb 23, 2014 9:21 pm
If you uninstall it though dosen't that mean that your used serial key is gone?
