samuraikav
PC Specification: i7-3770, GTX 770, Windows 7 Home Premium
OpenCL DLL missing
Sun Feb 23, 2014 10:50 pm
I just bought Action! and every time I open it, I get
Action.exe - Bad Image
C:\Windows\system32\OpenCL.dll is either not designed to run on Windows or contains an error.
First thing I did was go find the file, but the problem that comes up is the anti-piracy when I attempt to add the dll file. I have uninstalled all video related drivers and re-installed with no luck. I can use Action!, but it's annoying that this keeps popping up every time I load. Is there a dll file you prefer I download?
Please advise.
supercars22
PC Specification: Intel Pentium B970,Windows 7
Re: OpenCL DLL missing
Mon Feb 24, 2014 6:44 pm
So your anti-virus is stopping it? If it is disable it or disable firewall and anti-virus then it must let you get the file.
samuraikav
Mon Feb 24, 2014 8:58 pm
Sorry, its not my antivirus, it's the Action! Program. When I add the dll, Mirillis has a built in message saying I can get a legit copy or not.
The program loads without the dll but I wonder if it is stopping functionality. Where can I find an opencl.dll file that the program doesn't think is a cracked dll?
supercars22
Mon Feb 24, 2014 10:31 pm
A cracked dll means you got it online so it thinks you don't have a legit copy. You might need to contact mirillis. If you need the contact here it is. support@mirillis.com ;)
samuraikav
Tue Feb 25, 2014 1:30 am
I was able to fix this by installing DLL Fixer and the first thing it did was say that I had a corrupted OpenCL.dll file. It fixed it and everything is peachy!
supercars22
Tue Feb 25, 2014 4:14 pm
Great :D
