supercars22
PC Specification: Intel Pentium B970,Windows 7
How to fix some audio issues
Mon Feb 24, 2014 6:53 pm
If you click on Allow multi-channel recording it helps your audio ALOT so if your having any audio issues try just clicking that.
Wishing you the best,
Supercars22
KyrenCross
PC Specification: AMD FX 8350,GTX 780,WIndows 7,Xonar D2X
Re: How to fix some audio issues
Sun Mar 02, 2014 6:17 pm
I do this a lot, specially on 7.1 and 5.1 recording. It also captures audio cues behind me, even if I can't hear them in game.
The only problem I have is importing it in Sony Vegas. You can't import the audio only the video. I have to use another software like virtualdub to extract the audio and merge them in Vegas.
CyberLeo
PC Specification: Windows 7
Wed Mar 12, 2014 6:22 pm
Hello! I just bought Action today and it's working fine besides for some reason when I record my voice through my mic it only records through the left headphone/speaker. Any help would be awesome!
Thanks
CyberLeo
