Sieg2014
PC Specification: Intel i7, GTX 780Ti, Windows 7 64bit
Will i have to re-purchase?
Tue Feb 25, 2014 7:00 pm
I have a purchased licence of Action! and i need to re-install windows (complete formatt) to new SSD drives.
This means my Action! software will be wiped and i will need to reinstall it.
Does this mean i have to purchase another licence?
If not, how do i go about using my existing licence on my updated computer?
Thanks you.
-Sieg
Abuser
Re: Will i have to re-purchase?
Thu Feb 27, 2014 6:01 pm
No you will not have to purchase again.
Just install it again then check your email for the serial and re-enter it just like you did when you first bought it :)
chongis102
PC Specification: windows 7
Sat Mar 01, 2014 12:00 am
Abuser wrote:No you will not have to purchase again.
what if we deleted the email??? i want my action back
chongis102
Sat Mar 01, 2014 7:43 am
what if we deleted email
supercars22
PC Specification: Intel Pentium B970,Windows 7
Tue Mar 25, 2014 10:57 pm
If you want your problem fixed contact sales@mirillis.com for purchase support and I am sure they will help you.
MrTra1tor
Fri Mar 28, 2014 8:37 pm
Why would you delete an important email?... Also, I'm sure that the admins can see that your acount is linked with Action so they can verify you with a new key.
If not, well you're screwed
