CaptainMeatliBoy
PC Specification: Windows 7
Action! Codecs / Can't open .avi files
Wed Feb 26, 2014 7:52 pm
Hello Mirillis team and forum members!
I have a little problem with the action! files. The problem is that I cannot open the .avi files or I only see blackscreen and hear sounds.
I wanna render these files with Adobe premiere pro but it only shows blackscreen and sound as I already said.
I think its almost the same problem like he had: http://forum.mirillis.com/viewtopic.php?f=36&t=13543
Please help me with that!
Thanks for the help :)
Re: Action! Codecs / Can't open .avi files
Mon Mar 10, 2014 7:17 pm
Is Action! installed on the same PC where you are editing your video clips?
Return to “Mirillis Codecs”
