Thommy-L
PC Specification: Core I7 920, AMD R9 280x, Win7 64bit
[SOLVED] Action Causes Battlefield 4 to Stop Working
Sat Mar 01, 2014 3:16 am
I just downloaded Action as a trial. Since installing Action Battlefield 4 crashes when trying to join a server. This happens whether Action is started or not ever since it was installed and then started.
If I un-install Action, there's no difference.
I have to un-installe Action and BF4 and then re-install BF4, and then BF4 it works as expected.
If after re-installing BF4, I re-install Action, without starting it, then start BF4 and join a game (switch to a different window out of BF4 (without ending the game) I can start Action and it works.
If at any time I start action before BF4 is started and a game has been joined, BF4 crashes (Windows pop-up says that the program BF4 has stopped working) and it will not work again until I un- and re-install BF4. This persists even if I re-start window.
Thommy-L
Re: Action Causes Battlefield 4 to Stop Working
Sat Mar 08, 2014 6:41 pm
:oops: My bad. Issue was not caused by Action, Action just triggered it.
The cause is having "user.cfg" in the BF4 installation directory with the line "UI.DrawEnable 1".
The Solution is to delete that line. Then everything works. :mrgreen:
