BrutalSeverity
PC Specification: Win7x64, i7 3930k, Radeon 7870
YouTube HD Export - Multiple ID problem
Sun Mar 02, 2014 7:20 am
When YouTube decided to do the Google+ integration a while back, I opted to split up my YouTube account (Channel login and main account login). Picture below for clarification.
That is what I see when I log into YouTube (anyone who split their account into two also sees this). So, Action! doesn't seem to support this integration, unless I am blind and can't figure it out, because I get upload failed after it spends the normal amount of time it would take to upload. Am I doomed to Export normally, then proceed to upload to YouTube manually, or is there a way?
Thanks for hearing me out,
-BrutalSeverity
Re: YouTube HD Export - Multiple ID problem
Mon Mar 10, 2014 7:14 pm
Please inform our support team about this issue via support@mirillis.com.
satrincha
PC Specification: i7 4770k, 780ti, Win7 64b Pro
Sun Mar 16, 2014 12:28 pm
This fonction never worked for me ... i had tried with the 1.16.3. (don't remember the error name)
Now with the 1.18.0 i got after the compression : "error connecting to server" :cry:
Mon Mar 17, 2014 5:21 pm
Please check if you are able to change the default YouTube account.
