maca
PC Specification: windows 8
exporting
Mon Mar 03, 2014 6:08 pm
I'm thinking of buying action but when I try to use the exporting system but the percentage bar doesn't go up it stays at zero
but the time bar goes up I also tried doing it manually by dragging it from my files to YouTube when the download is says The video has failed to process. Please make sure you are uploading a supported file type but the file is the correct file type
what should I do please help also I am new to this software
Re: exporting
Mon Mar 10, 2014 7:10 pm
Please update your graphic card drivers or uncheck Hardware Acceleration in Export Settings.
maca
Re: exporting
Wed Mar 12, 2014 6:33 pm
thanks that worked but now at the end of exporting it just says export failed is there anything I can do to stop that
Re: exporting
Wed Mar 12, 2014 7:00 pm
Try disabling your hardware acceleration in Export Settings.
maca
Re: exporting
Wed Mar 12, 2014 7:32 pm
I have done that but at the end of exporting a little window pops up and says exporting failed is there anything I can do.
