Samithman
PC Specification: windows 7
Will only record in MP4?!?!?
Mon Mar 03, 2014 11:27 pm
So after a few weeks of enjoying action, I am being pestered with annoyance! for some reason the software has decided to only let me record in MP4 even though I have the AVI option selected! please help me out!
Re: Will only record in MP4?!?!?
Tue Mar 04, 2014 10:56 am
Uncheck "Enable Action! LIVE Streaming".
Sajakain
PC Specification: Core i7 860, 4GB GTX 680, Win 8.1
Tue Mar 04, 2014 11:09 am
radi wrote:Uncheck "Enable Action! LIVE Streaming".
My apologies ahead of time for derailing the thread but, Radi, how long does it take for threads to be approved and posted around here? I submitted a thread roughly 24 hours ago and it's still yet to be posted.
I have never found the perfect quote. At best, I have found a string of quotations which merely circle the ineffable idea that I seek to express.
Linark
PC Specification: Radeon 7870 HD
Tue Mar 04, 2014 12:20 pm
I have the same problem with the 1.17.0 update all the videos in Mp4 recorded me and I can not change.
My Pc:
Procesador - AMD FX-6100 a velocidad de 3.30 GHz
Placa Base - ASRock 985GM-GS3 FX
Memoria - 8 GB memoria total de tipo DDR3
chip de memoria Kingston de 4 GB
Tarjeta grafica - AMD Radeon HD 7800 Series
Mon Mar 10, 2014 7:28 pm
Usually it does not exceed the 24 hours. If it's longer send a tip to support@mirillis.com.
