MadMan1300
PC Specification: unknow
Need some Help
Tue Mar 04, 2014 1:01 pm
So i need some help so here we go.
1. If i turn on Record Microphone into separate audio track will it make two Tracks in Sony Vegas when i get around to buying it.
2. My audio from my Blue Yeti sounds like shit after i make a video i go back and have a look out it and its sounded like i had the Microphone right in front of me when i did not.
3. Is there a way to make the file size of the videos smaller with out making the Video quality Lower.
4. Can you remove HotKeys so you dont hit them when you are playing a game (E.G. turning on Record Audio, Benchmarking and so on) .
Thank you for taking your time to read this. :D
Re: Need some Help
Mon Mar 10, 2014 7:10 pm
1. Yes.
2. Make sure that your yeti microphone level matches your microphone audio settings in Action.
3. Use MP4 instead of AVI.
4. Currently no.
