cesarcrfilho
PC Specification: FX 6300 3,5 GHz; RADEON 7850 HD; Win7 64
Action! echo issue
Wed Mar 05, 2014 12:50 pm
Hello, guys,
I'm trying to record a commented gameplay video, but I'm experiencing a noisy echo. I searched the forum for some solution, but none of then seems to solve this.
Here's a video example:
http://www.youtube.com/watch?v=FhE3DMxJ ... e=youtu.be
I'm attaching my configurations.
Could you please help me fix this?
Thank you!
Action! issue.jpg (248.08 KiB) Viewed 8025 times
MiRai
PC Specification: W10 x64
Re: Action! echo issue
Wed Mar 05, 2014 11:21 pm
You've told your microphone to always record everything all the time... So, is that feedback from your speakers that's producing the echo? If it is, then you're going to need to turn down your speakers or use a headset.
cesarcrfilho
Tue Mar 11, 2014 6:29 pm
MiRai wrote:You've told your microphone to always record everything all the time... So, is that feedback from your speakers that's producing the echo? If it is, then you're going to need to turn down your speakers or use a headset.
I'm using a headset, so that's probably not the issue's root.
