AryJaey
PC Specification: Intel(r) Core(TM) I3 CPU 550; RAM:4GB
Audio is weird!
Thu Mar 06, 2014 11:30 am
I recently use Action! and I like it!
It has a nice UI and it doesn't eat your FPS.
but however, the audio is a little weird.
when recording footage my sound (with mic) and also the voice of my friend through skype is a little bit glitchy...
I don't know why it is like this... I tried everything...
"use multi channel" is also checked btw.
And when I record my audio with 'audacity' there's no audio glitch problem, but the problem there is that the audio is not in
sync with the video...
I uploaded my videos on youtube so you can check out what I mean:
audio recorded with AUDACITY (so out of sync but no audio glitch):
https://www.youtube.com/watch?v=4rgJgCYM79Y
audio recorded with ACTION! (so in sync but audio glitch):
https://www.youtube.com/watch?v=hAezVgBLP8Y
I hope you guys can help me!
AryJaey
Re: Audio is weird!
Mon Mar 10, 2014 7:08 pm
It seems that your microphone is gathering all the surrounding sounds. What microphone do you use?
DrZ
PC Specification: Intel i3 530 @2.93GHz, Radeon 7770, Win7
Re: Audio is weird!
Thu May 08, 2014 9:51 pm
bump
Hi there,
I have exactly the same problem with Mirillis. And it is not a problem with a microphone. I used to record with Mirillis and Audacity and everything was absolutely fine (on older version, before you switched to the new codec - btw do you now, how to record with Audacity and Mirillis with FIVC codec, because the audio is always longer than the video)... anyway... I noticed this crackling sound in voice track when I record in 1080p... when I record in 720p, it's ok (although recently the same crackling sound happened to a video of Dead Island Epidemic recorded in 720p).
Because of this problem I can't record most of my videos in 1080p. I thought it is because of lower specs of my computer - i tried to lower the quality of voice track, but it didn't help.
NostalgiaNerd
PC Specification: 486DX2/66 4MB RAM, 500MB Hard Drive
Re: Audio is weird!
Wed Mar 22, 2017 1:44 pm
I realise I'm a little late to the party, but for anyone who might be searching with a similar problem;
I encountered this issue whilst using version 2.3.0.0 or Miriliis Action!
I solved it by changing the audio device away from my Blue Snowball Microphone and instead to the "System Default". Before I did this, there was a crackling sound across all voice tracks.
Bizarre behavior.
You'll need to change the setting in Audio Settings and Microphone Settings. Job done.
eeww
PC Specification: windows 7
Re: Audio is weird!
Sat Apr 01, 2017 8:25 am
I met the same issue whilst using version 2.3.0.0 Miriliis Action.and i searched a lot until i downloaded the android avi software. I solved this problem by changing the audio setting through the software. After i did this, it was no any crackling sound anymore. :roll:
