aeroteq
PC Specification: Microsoft Windows 7 Ultimate SP1
Action unable to record secondary display
Sat Mar 08, 2014 9:00 am
Just testing out Action! as recommended by a friend (have framerate issues when recording with my current software)
Setup seemed easy enough, though no matter what I do I can't get my secondary monitor to record. My primary monitor is off to my left, and my secondary is directly in front of me, and my racing wheel, so dragging my game over to the left isn't possible, really.
Screenshots seem to work just fine, but when recording, it just doesn't recognize my secondary monitor. Even if I try recording in a region, it just records the region on the parallel monitor. i.e if I set it up to record my bottom left of my secondary, it records bottom left of my primary.
Re: Action unable to record secondary display
Mon Mar 10, 2014 7:05 pm
Please make sure that your second desktop is set as active desktop (blue HUD indicates active desktop). You can switch between active desktops using F8 key.
