Adwen
PC Specification: i5 2500k nvidia gtx 660 windows 7
Enormous Aero problem
Sun Mar 09, 2014 12:16 pm
To begin i'm french , if i make mistakes in my topic i apologize
So Action asks me to record my desktop to activate Aero , if i understood well i have to activate aero themes in the customization(personalization) and appearances .
But when it is made, the error messages come back : "The recording of the desk is impossible because aero Windows is desactivated. Please activate him to record the desk
I don't understand where the problem comes from ! please help me
Re: Enormous Aero problem
Mon Mar 10, 2014 7:03 pm
Try running Windows troubleshooter for Aero interface and see if it finds any issues.
Adwen
Mon Mar 10, 2014 7:28 pm
Unfortunately, the troubleshooter find nothing .
What can i make of more ? Have you a solution?
Adwen
Sat Mar 15, 2014 4:42 pm
Help me please , i need you
jax<>
PC Specification: Intel 3770K, Gigabyte 660GTX, Windows 7
Wed Mar 19, 2014 7:49 pm
Hi, do you have Lucid logix virtu mvp installed by any chance?, I had this problem and it was down to Lucid logix virtu mvp
I contacted Lucid support and they ask me to uninstall virtu mvp selecting delete personal data, reinstall pro version from there website, they also gave me a new activation code, and it solved the problem,
as a test try entering services.msc into windows run box (press windows key + r) press ok, look for desktop window manager and restart the service this switches dwm aka aero on, I was doing this before the main fix as a temp solution
Hope it helps someone
jax<>
