Taur.XCI
PC Specification: i7-3610QM @ 2.30GHz, GTX675M 2G, Win 8.
Video seems to be forwarded.
Mon Mar 10, 2014 10:54 pm
i bought Action! probably about a year ago and it has been working really good need to say is one of the best recorders i have ever tried, however since a week ago when i record anything the video seems to be forwarded for example
if i record a video of 20 seconds, the video will make it 15 seconds speeding it up, if i do a minute video the same will happen sometimes is 10 seconds or sometimes is 15 but never the exact amount of record if the video is one minute the video will forward jumping from frame to frame some scenes from the record.
25yeargamer
PC Specification: Windows 7 Home Premium, nVidea GTX
Re: Video seems to be forwarded.
Wed Mar 12, 2014 3:28 am
I am seeming to have the same problem and I'm getting really frustrated.
I'm trying to do some 20-30 minute let's plays and after about 5-10, my video and audio go to about 3x speed (with the occasional normal speed for audio in strange segments).
Please someone figure this out!!!!
Wed Mar 12, 2014 7:01 pm
Could you post a video sample?
25yeargamer
Wed Mar 12, 2014 10:43 pm
radi wrote:Could you post a video sample?
Here's mine. It's on private. Reply if you have any problems getting to it.
http://youtu.be/neX3Oe10dVc
MiRai
PC Specification: W10 x64
Thu Mar 13, 2014 12:20 am
No one except you and a list of people that you specify can see a privately listed video. If you want to share it with others, but not broadcast it publicly on YouTube, then it needs to be set to Unlisted.
Thu Mar 13, 2014 5:07 pm
Please check if you disable recording system sounds the same issue occurs.
25yeargamer
Mon Mar 17, 2014 9:21 pm
Sorry about that. I always mix "Private" with "Unlisted." The video should be viewable now.
25yeargamer
Mon Mar 17, 2014 9:23 pm
radi wrote:Please check if you disable recording system sounds the same issue occurs.
I'm making "Let's Play" videos. I kind of need the system sounds on. I don't really care for temporary fixes. I kind of want the issue resolved. Also, it still has the same problem. I disabled recording for system sounds and it continues to do it.
