mrmister
PC Specification: Windows 8.1
Impossible to capture from DirectX/OpenGL
Thu Mar 13, 2014 2:35 am
Hello
I am trying to capture from DirectX/OpenGL but I cannot... I see the button gray and I cannot press it.
I don't have that problem with the active screen button, then I see the red button to record from the screen.
If I press the gamepad button (to record from DirectX/OpenGL) then I cannot record anything, because the record button is gray...
How may I solve this?
Thanks
Re: Impossible to capture from DirectX/OpenGL
Thu Mar 13, 2014 3:36 pm
The button is always grayed out. In this particular mode you are starting your recording with F9.
mrmister
Thu Mar 13, 2014 5:21 pm
I press F9 and has absolutely no effect, it doesn't record anything, I've search in the folder were allegedly should be the videos, but the folder is empty and the recording never start.
To be sure the F9 key is not being used by the game, I have selected other combibation of keys to start the recording Crtl + Shift + F9 and continue the same, don't record anything.
The game is X-Plane 10.
You can download a demo from here:
http://www.x-plane.com/downloads/x-plane_10_demo/
Perhaps you may download the demo and doing some tests... so you could find for what reason Mirilis is not detecting the game?
Thanks
Cassutt Pilot
PC Specification: Win 7
Sat Jan 03, 2015 12:38 am
Just installed Action and having the same issue not recording in X-Plane. Have you found a fix?
Thanks
Win 7 (64 bit), ASUS Maximus VII Formula MB, i7-4790K @ 4ghz, 16GB Corsair Vengence Pro series DDR# @ 1866mhz, ASUS Striker Platinum GTX 760 4GB DDR5, Samsung SSD 840EVO 500GB
