sjarboe01
PC Specification: i5-2500K, GTX 1060, Windows 10
Contact: YouTube
Nvidia CUDA or Intel Quick Sync? Both?
Fri Mar 14, 2014 8:29 am
So, I have been using Nvidia CUDA as the hardware acceleration. But I am recording with the Intel Quick Sync MP4 format. Does that mean that it is using both of those things for double the speed/less impact? Or is it only using the CUDA/Quick Sync? Hopefully someone can answer me.
Claunator
Re: Nvidia CUDA or Intel Quick Sync? Both?
Thu Mar 20, 2014 8:38 am
I think it only uses Intel Quick Sync. CUDA is the acceleration in ur GFX card and Intel Quick Sync comes from the motherboard itself as integrated GFX. Quick Sync has a lower impact on performance and is supposed to be more "recording-friendly" for that matter.
Tue Mar 25, 2014 3:52 pm
It only use IQS. Only Intel Quick Sync provides a possibility to compress the video in real-time.
