crystall
PC Specification: Windows version
Action! Exporting + Vegas
Tue Mar 18, 2014 4:10 pm
Well, I think everyone had this problem before, after exporting, I can't edit my video using Sony Vegas because Vegas imports only sound.
Export: http://i.imgur.com/Hy1tcav.png
Import: http://i.imgur.com/OM40rIo.png
Please help.
MiRai
PC Specification: W10 x64
Re: Action! Exporting + Vegas
Thu Mar 20, 2014 12:00 am
I don't use Vegas, but have you tried recording to AVI instead and editing the video that way?
What you're doing now is you're exporting to a lossy format (H.264) just so you can drop it into Vegas, edit it, and re-export it to yet another lossy format, so you can, I'll assume... upload it to YouTube and let YouTube re-encode it again as a lossy format. You're just killing the quality of your video.
Abuser
Thu Mar 20, 2014 6:24 pm
Are you using the latest version of Action!? If not I suggest you do.
What format are you recording in?(AVI,MP4)
Also when you want to use Vegas Pro with it I don't suggest exporting. Just grab then finished recorded file and imort it into Vegas Pro without exporting from Action!.
I use the latest version of Action! And record with Intel QuickSync and I imort my videos to Vegas Pro 12 without exporting and it works like a charm.
jax<>
PC Specification: Intel 3770K, Gigabyte 660GTX, Windows 7
Fri Mar 21, 2014 6:12 pm
Yep same as Abuser, I have movie studio platinum 12 and just drag mp4 clip into moviestudio and works perfect, make sure you got latest version of quicktime installed.
