oTe
PC Specification: 4790K@4500MHz, 980TI, Win10, 16GB RAM
Sound dropouts using AMD APP
Tue Mar 18, 2014 5:50 pm
I'm Recording MP4 Original or 1080p with AMD APP! Every few seconds i have sound dropouts. Sometimes more, somtimes less.
No problems with .avi recording, only with AMD APP.
Any Ideas?
System:
FX 8350
7970GHz 14.2 driver
Win 8.1
Mic Rode NT2a and Headphones Beyerdynamic DT770Pro connected @ Audiointerface Steinberg UR22 with Yamaha Steinberg USB driver 44.1khz 2048 samples.
oTe
Re: Sound dropouts using AMD APP
Sat Mar 22, 2014 7:35 pm
Solved the problem. Deactivated the second monitor (windows key + P). No more sound dropouts. :shock:
Tue Mar 25, 2014 3:43 pm
Thanks for sharing your solution.
Montago
Wed Mar 26, 2014 9:43 am
do you have a USB soundcard in your system somewhere ?.. maybe monitor Audio ?
oTe
Wed Mar 26, 2014 1:02 pm
Montago wrote:do you have a USB soundcard in your system somewhere ?.. maybe monitor Audio ?
Using my audio interface UR22 soundcard which is connected with USB! (look first posting)
Montago
Wed Mar 26, 2014 1:31 pm
oTe wrote: Using my audio interface UR22 soundcard which is connected with USB! (look first posting)
oh yea.. i missed that.
I suspect that it could cause troubles, given that USB audio is rather unstable.
but since you solved the problem with a monitor 'detach' it's more likely that it could be a DisplayPort / HDMI issue (which again is a sound-card / USB audio issue)
